2.3 TL high static/white noise from top tweet and some from tweet below
GlennDog
I really have no idea where to start. It's the right speaker only. Xovers were done by previous owner. I've never open these puppies up, but I guess I'm about to.
But not tonight, maybe in the next day or so after I get some feedback . . . For tonight I'll have to roll my Salks in
Don't get me wrong, I like rolling equipment. I just don't want to be forced to do it
Other than a loose connection, what are my first 2-3 things to look for?
TY !
TY !
Source Lumin U1 Mini into Lampi Baltic 4
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
Try a different pair of speakers to make sure it's the 2.3TL and not anything earlier in the chain?Jay
Loose connection or cold solder joint.Political Correctness'.........defined
President of Club Polk -
Bad music. Maybe boy bands. A good set of speakers have been known to commit hara-kiri when exposed to it.
The Salks are in and static is coming from the right ribbon!
I checked the bias in both mono blocks and they're where they should be
I guess I'll switch out the tubes in the preamp
What's next gents?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Flip each L/R source RCA and or preamp/amp till you narrow which piece of gear it follows...don't forget to power down each time2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
You might start switching speaker cables left-to-right, then interconnects as well, to see if one of them is the guilty party.Jay
Thanks for all your help guys, but it turns out to be minor surgery
Apparently, the tubes I recently acquired from the "RealGreatGreatSeller" from the Great White North are faulty
I'll have to send back and get a refund. I hope he's cooperative
On the upside, I'm really glad that the Polks don't require disassembly and the Salks sound fine
Thanks again for your quick responses!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Nope I think that was a little premature
the static is coming back What the eff?..AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Too much crazy stuff in too short of time. I'm gonna throttle back and post laterAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Recent tube change? Could be dirty pins.
Yes, sir! It's a tube issue for sure . . . 12ax7 input tube in right side mono block
(Too many changes in a short time, .... I owe GreatGreatSeller an apology)
Not sure if it's defective or dirty pins, it was just delivered in the last week or so and pins were supposed to have been cleaned . . . . I'll be purchasing some de-oxit STAT
Dag Nabit! These tiny Salks pack a mighty punch and sound eff'n great!!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Keep on rockin' \m/
