REW setup help
gmcman
I have used this before with my room turned another way, but the results were much different. Maybe I have a setting wrong, not sure, but basically it's at the default setting, I'm using a laptop with the headphone out, stereo 3.5mm plug to stereo rca into the preamp. The usb mic is connected to the laptop, calibration files used.
My sweeps are very jagged, 1/6 smoothing is all over the place so maybe it's just how the room is, maybe I have something wrong, I will post a graph when I get home.
If someone well versed with this and SDA's would like to PM me with their contact Info, maybe we can figure this out via phone call if that would be easier.
Thanks.
Thanks.
Here's a 1/6 smoothing graph, as well as some settings.
Well it seems you aren't supposed to use a soundcard calibration for the laptop when using usb mic. I cleared the soundcard file and all is good.
