Help
mguevarra61
My CDP took a dive, just won't read discs, keeps displaying no Play and then sometimes will play discs and then stop in the middle of it and sometimes it just plays a whole disc through but I will more often than not hear skipping. At any rate, the CDP has a DAC that can be used when hooked up to a different transport. Don't have the money right now to buy a dedicated CD transport (although the Cyrus models look good IMO) and so I am faced with using my Sony DVD player as a CD transport. This has a Digital Out. I have a Kimber OPT-1 cable handy and so here's the question: Will I connect the OPT-1 from the DVD player's Digital Out and then into the CDP's Digital In (Toslink)? The Interconnects I have from the back of the CDP can remain connected to the preamp and then interconnects from the preamp to the amp? Is this how I need to set this one up? I have been forced to listen to Cds for the past couple of days without an external DAC so to speak (I think I am saying this correctly since I am going to use the DAC portion of the CDP only now). Help.
Try cleaning the lens on the optical pickup. Use a Q-tip or the like slightly damp with denatured alcohol. Do this with the CDP unplugged.Political Correctness'.........defined
President of Club Polk -
You don't think I'll damage the DAC portion of the CDP by doing this? One dude said that it is possible tha tthe laser diode is dying? I have never done anything like this, as you suggest.
No, you will not damage the DAC by cleaning the lens. It could be the laser diode, but it could simply be a dirty lens.Political Correctness'.........defined
