Technics SL-Q6 turntable problems.
Woody_Harrison
I recently hauled out my old SL-Q6 turntable to play some LPs, and it is not working. Que ^ light is on, the turntable does not turn, and none of the front panel pushbuttons (except on/off) work. Anyone have an idea what might be wrong?
Does it work of you give it a manual spin?I disabled signatures.
Also the arm is belt driven linear tracker. Long storage can ruin the belt and cause it to break or melt which would be why the arm is not moving?....2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
How do I get into the arm mechanism? I see two screws on the back to remove the cover/arm, but don't see how to get into the tracking mechanism.
