Audioquest Rocket 88 Single Speaker Cable 8ft Bi-Wire High Performance
dekuda
Have for sale a Audioquest Rocket 88 Bi-Wire 8 foot single speaker cable. This is a very high end audiophile quality cable that can be used for your center channel.
Haves AudioQuest’s DBS 48v Dielectric-Bias system.. Battery when tested is green/okay.This comes in the original OEM box and velvet bag from Audioquest. Haves four heavy copper spades on the speaker end and two bananas on the amp end. Asking $185.00. Shipping priority is $18.75 flat rate or I can ship slower for less. Thanks!
http://www.audioquest.com/rocket-series-speaker-cables/rocket-88
HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
Post edited by dekuda on
24461f391e20b7336331d5789078af53.r23.cf1.rackcdn.com/polkaudio.vanillaforums.com/editor/wg/60w148ykbuby.jpg
HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
Price drop to $170.00HT System
I cannot use this as my Martin Logan Motiff center only haves two connectors and cannot be bi wired. Bump to $150.00 plus shippingHT System
why can't you put both on the same post? -
There is no sonic improvement to me when I did it. Plus I already have decent cables in my system. Just wanted to try these out..I purchased this thinking I had dual post on the back of my center. When I pulled it out I was shocked to find only one set. I believe also that certain crossovers are not designed to be bi wired. I believe this is the case with my ML. That being said, the ML Motif is the best center I have ever owned.HT System
You can also send it to AQ and they will re-terminate it to a single wire for a nominal fee...
I'm interested. You can email me at rahualn@gmail.com
