Polk SB1+ ac adapter specs help!
witchcraftz
I have contacted Polk directly but no answer so I am reaching out here. I am looking for the specs on the power supply for the soundbar of the SB1 plus.
my soundbar ac adapter has gone MIA and I'm hoping to find an adapter out of my box of them which might work.
So I'm looking for:
Voltage (24v?)
Amperage (2.5A?)
Polarity (plus inside?)
Plug connector size (5.5 mm OD, 2.5 mm ID, 9.5 mm length?)
So I'm looking for:
Voltage (24v?)
Amperage (2.5A?)
Just buy a new one from Polk.Political Correctness'.........defined
President of Club Polk -
Polk's CS department should be able to confirm those specifications as well as provide information on ordering a replacement. Give them a call at 1-800-377-7655.
