Polk RM 6752
sandeadmarsh
Hello...I'm brand new to this forum but I was wondering if someone could help me....
I have the Polk Surround System 6750 I believe. The problem I'm having is the center speaker. Someone pulled on the speaker wire and pulled both plastic clips out of the back of the speaker. I can hook up the speaker wire to both sides but if the speaker is just barely touched...it disconnects and of course no sound comes out of it...is there an easy fix for this? I would buy another center speaker but they are 80 bucks brand new! Ouch! If someone could help me that would be great!
Thank you in advance!
Mike
Mike
Answers
Hi Mike,
Welcome to Polk's forum. Somebody is going to have to replace the input cups on the speakers. If you are moderately handy with basic tools you can do it yourself. If you'd prefer, any general audio repair shop should have no problem making the speaker work.
Regards, Ken -
Thanks Kenneth for the quick response....I've already put in a call to a repair shop so hopefully can get this problem fixed and at a decent price...if not I'll probably have to buy another one which would really suck!
You're welcome, the repair should be reasonable.
