SDA 3.1tl resto-mod
Picked up a pair of "well loved" SDA 3.1tl speakers for $200. Yuck, but sounds like a fun project. All the drivers were in place and in good shape except for pushed-in dust caps.
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
«13
  • gwg_97
    gwg_97 Posts: 332
    Off with the end caps (which are glued in place). Used a hand sledge from the inside. Not too bad.p2ovkcf0m2z7.jpg
  • gwg_97
    gwg_97 Posts: 332
    edited June 2016
    Built some new end caps with 3/4" mdf and made them flush with the cabinet using a router, trim bit, brads, glue, and good old bondo. Then I used a heat gun to remove the damaged black vinyl from the front and back of the cabinets.au8506ub5yik.jpgju8il5rdq3rk.jpg
  • gwg_97
    gwg_97 Posts: 332
    With the side panels off the grills no longer fit flush with side of the cabinet. Time to break out the router again. I clamped the grill frames to the cabinet and cut them flush with the side of the cabinet using a trim bit and then did a 1/2" round over (as was used on the original grill). qhorptc7hw9c.jpg
  • What are you going to use to replace the vinyl? Nice job getting them cleaned up
  • gwg_97
    gwg_97 Posts: 332
    Thanks! I'm covering all sides with raw cherry veneer.
  • Dennis Gardner
    Dennis Gardner Posts: 4,860
    edited June 2016
    Interesting choices, awaiting the finished product..... if I was going that far with the reveneer, I would choose a inlaid magnet system for the grills so that the ugly ball joint system was replaced. meniscusaudio.com/grille-fasteners-c-108.html
  • westmassguy
    westmassguy Posts: 6,850
    They're going to be beautiful, and a very unique pair for sure.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Mike Reeter
    Mike Reeter Posts: 4,314
    I would second this idea, when the Cherry Veneer is finished, you will always want to leave the grills off when listening, just to admire them.
    I also like the way you have trimmed the top caps and grill frames to be flush with the cabinet, I never really like the slight over-hang either.
    Looking forward to the finished product, I'm betting your new 3.1's will be gorgeous!
  • Faustin
    Faustin Posts: 1,147
    Great project. Very nice work. Looking forward to seeing them when you are finished.
  • machone
    machone Posts: 1,469
    Very nice!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • vmaxer
    vmaxer Posts: 5,116
    Looking great.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Gunther16
    Gunther16 Posts: 243
    Awesome idea with the cherry veneer, Will you be updating the electronics too? Looking forward to the finished product. Good luck and good sound. You will be a happy camper.
  • GospelTruth
    GospelTruth Posts: 403
    Looks amazing.
    I have a set of 3.1s that I will look to revive one day as well. I wanted to refinish the caps on mine due to water damage. I know that the endcaps on the 3.1s are not the "removable" type like on the 1.2s and 2.3s. I thought about trying to build that functionality into mine once I take the caps off - like you've done with making it flush but then putting the caps on top of that. However, I wondered if the slight change in volume on the speaker interior would somehow affect the sound at all. I figured they were built with a certain volume in mind, and if basically putting in two sheets of plywood on the inside would somehow alter things. Maybe someone can answer that - or you can once they are up and running. They do look pretty amazing though. Don't know if I have the skills at this point to do what you're doing. Wish I did.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
  • westmassguy
    Definitely the nicest pair of 3.1s I've seen, simple, eloquent. The slab top and bottom with wrap-around grill cloth is old hat. Add some nice spikes, or even outriggers with spikes, running front to back. Excellent work.
  • Mike Reeter
    Looks amazing.
    I did this very thing to my 3.1TL's, the original caps were trashed so I added a new base (recessed inside the cabinet) for replacement caps to be glued or bolted onto.
    The new cap in place
    I also wondered about the internal cabinet volume dimensions that was displaced by the new "cap bases" that I installed, I installed the new top and bottom bases on both cabinets.
    I think they sound wonderful and wouldn't concern myself if I were you!
  • Mike Reeter
    gwg_97 wrote: »
    Great idea to use the magnets but unfortunately I already used the Titebond II iron-on method to glue the veneer down. I'm happy withe results but the veneer ended up splitting a bit (not a big surprise). I will do the Crossovers, dynamat, RD0198s, etc. after the cabinets are done. Sonicaps on the high pass and either sonicaps or a less expensive set of caps on the low pass (daytons?). Any suggestions?
    I would stay with Sonicaps throughout, you don't want to have any "what if's" with this beautiful set of SDA's!!!
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,060
    All the work is certainly IMPRESSIVE!!
    Harry / Marietta GA
  • GospelTruth
    Awesome! Thanks for the reply and glad to hear your thoughts on what impact the new caps have on the overall sound. I'll probably go that route then when I get around to restoring the ones I have. Of course, looking at the creativity with the 3.1TLs in this thread could make me want to try something else. :)
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
  • Mike Reeter
    Ha!, yes gwg_97 has me daydreaming about a "Winter Project" ;)
  • westmassguy
    Get 'er' done Mike
  • willwilly
    willwilly Posts: 185
    Sweet build... I'm hooked!
    Will I am
  • Are you taking measurements by any chance? I am not sure anyone would ever want to do scratch built cabinets but it would be nice to have accurate measurements just in case.
  • gwg_97
    gwg_97 Posts: 332
    Hey everyone! Thanks for all the comments! I got a few coats of Daly's Profin on them over the weekend and that's it. My Dynaco had some magic sparks on Saturday :'( and I was really busy.
    I think I'll build some outriggers for these guys ASAP (great suggestion). Also, I'd be happy to take some measurements if anyone is interested.
    EndersShadow Posts: 17,517
    gwg_97 wrote: »
    If your lazy like me (which given what your doing is doubtful) there is a company that MAKES outriggers so you'd just need to install them. May save you time later on.
  • HzTweaker
    HzTweaker Posts: 721
    Fantastic choice with the cherry veneer!
    2ch rig:Speakers: LSi9s with VR3's Fortress modsPreamplifier: Parasound P5Amplifier: Parasound A23CDP: Pioneer DV-563ACables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
  • gwg_97 wrote: »
    I am interested in having measurements. Thank you
  • lawdogg
    lawdogg Posts: 449
    I'd LOVE to see pictures of the finished cabinets!
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • gwg_97
    gwg_97 Posts: 332
    Update, I have about 5 coats of Daly's ProFin (wiping varnish) on them now. I need to wait about a month before I can do a "hand rub" with a 2000 grit Abralon pad. If all goes as planed, they should have a nice satin finish when I am done. Time for the crossovers, dynamat, etc.
    I'll post measurements/dimensions tonight. m492dcm7pppc.jpg
