System Set Up Help
Hi everyone. It has been a long time since I have installed any car audio equipment other than a head unit replacement or speakers. I am installing (2) MM651 and (2) MM691 speakers in my boat (no subs). They are powered by a Polk D4000.4 4 channel amp. My questions are what would be the proper amp setup for this scenario. I was told that because these speakers have factory crossovers that I should set the amp to full range and simply adjust the gain. Is this correct? If not can anyone give me suggestions for the amp settings?
  • DSkipDSkip Posts: 14,882
    No. You want a low frequency cutoff for the woofer. The crossover will only filter where the tweeter and woofer overlap. 60 hz should be good but play around. Don't drop it less than 40, preferably 50.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
Howdy, Stranger!
