Parasound A21 Vs JC-1 Mono blocks
acmf74
acmf74 Posts: 936
edited May 2016 in Electronics
Looking into Parasound amplification.
Do both amps sound the same or do the JC-1s more sound musical?
Thanks.
    nooshinjohn Posts: 25,100
    JC 1's all day long for me.
    txcoastal1 Posts: 13,132
    ^^^^This
    If you are looking give DSkip a holler, he's a dealer
    tonyb Posts: 32,906
    I'd concur with the other gents....The JC1's are on a way different level than the lower lines. They should be too given the price difference but they were built to be a flagship amp and not just an updated series.
  • Joey_V
    Joey_V Posts: 8,520
    This question has been one of those I've been curious to answer myself.
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • ukcolin99
    ukcolin99 Posts: 286
    To repeat, aren't we comparing new $4500 each x 2 vs one $2500 amp?
    I love my A21 gotta think I'd marry a pair of JC 1 Monos if they showed up at my door..Twins..
  • Emlyn
    Emlyn Posts: 4,372
    A JC1 amp is capable of 135 amps peak to peak power output compared to the 60 amps per channel on an A21. It also has a 1.9kVA transformer compared to the shared 1.2kVA transformer in an A21. The internal build quality is more robust all around to accommodate the higher power output, which allows the JC1 to run up to 25 watts in pure Class A mode. This bias mode would make it sound more musical, as well as being capable of greater power output. The design philosophy and many parts are the same though, including the chassis, to save money in the product line. I am happy with an A21, but considered getting a pair of JC1s over the years as the A21 can sound a bit solid state "grainy" when pushed hard compared to higher end amps.
  • acmf74
    acmf74 Posts: 936
    Thanks everyone!
