B&K Components Mono Blocks 220M
acmf74
in Electronics
Looks like Reference series, 250wpc, 150A p-p.
Should be typical B&K smooth, fat and impactful, going by the numbers. Should have balanced inputs, too.
Some say the later models of B&K stuff weren't as good as the early Sonata series stuff, but I couldn't say for sure either way, having only had experience with the Sonata series, the latest Reference series (a 200.2 not listed on this spec sheet) just before they went out of business, and the AVR series. I can say that my experience with both of those has been very pleasing, and similar sounding, but no experience with the middle age gear.
If you've never had B&K, always been curious, like your audio with a bias toward smooth over being extra detailed, and you can get a good deal on them, I say go for it. Bonus if they've got the OE boxes and packing materials. I almost tried a set of Sonata monoblocks a couple of times over the past couple of years, but there was some slightly different build version for a while that doesn't appeal to me. They had sloppy external heat sinks hanging off the on the back instead of internal, along with oddly positioned, unmarked inputs layout, and weird, wimpy looking rack mount handles on the front.
Unless B&K really hosed something up with some bad design change ideas before reverting to something similar to the Sonata builds for their final series, I'd say they'll probably sound similar to the two series' I mentioned, which I enjoy. Sorry, I know this is just speculative and you're looking for a first hand account.
Also, something to consider, coming up on 14-16 years old, they may need some attention?
Maybe @mantis and @tonyb can chime in here. I think they both have broad experience with B&K.
Here's a link to the Previous Amp Specs from B&K if you didn't already have this.
Post edited by msg onI disabled signatures. -
I have b&k reference s2 mono blocks, they are smooth as butter, powerful, and very reliable. A friend of mine has the sonota mono blocks and has had them for years, he runs some hard to drive revel F50a towers without a hitch. In my opinion for the money b&k is hard to beat.
The reference s2 does have balanced inputs.2 channel:
Theater:
