SRS Interconnect Cable
timtam77
Hello, I'm looking for a replacement 2 blade interconnect cable for my SRS. I got one off of Ebay but I am disappointed in the quality. Does Polk still make them?
Thanks,
Tim
Thanks,
Tim
Yes, they do. However, it may not be different from the one you purchased. Polk makes them up these days as a courtesy. They do not have the molded on ends like the originals. A lot of us here swap out the stock SDA socket for an air tight, 4 pole Neutrik socket, then make a new SDA cable using high quality speaker cable with a matching 4 pole male Neutrik plug.Political Correctness'.........defined
President of Club Polk -
Thanks. I may want to change my set up.
