Adding an amp to my reciever
Gstradeski
I have a pioneer SC 1228 receiver with two rtia7s for my front speakers. I feel like the receiver does not have enough power to properly run them. I am thinking about getting a stereo amplifier to go through my preouts. Just wondering derived g if anyone knows if I should be ok with what I have or if the additional power would be beneficial
Also wondering what a good amp for the rtia7s would be
Is your question in reference to HT or 2 channel music?Political Correctness'.........defined
President of Club Polk -
2 channel
Yes it would be beneficial. Parasound is good with A7
I don't know what paramount is
If your system is 2 channel only using an AVR as the pre amp isn't the best idea. A dedicated 2 channel pre amp will have better sound. Anyway. Chumlie suggested a Parasound power amp, which is a good suggestion. It's on the warmer side and will help tame those tweeters a bit.Political Correctness'.........defined
Gstradeski wrote: »I don't know what paramount is
http://www.audioadvisor.com/prodinfo.asp?number=PAHA23&variation=BLK -
Look for a used Parasound HCA 1200 OR 1500. Usually around 400 bucks. They make excellent first amps and sound great with RTI's, and.....won't break the bank.HT SYSTEM-
lsi 9's -
A Parasound HCA-1000 will "get 'er done" if you don't need to lift your place off the ground.Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
