Do PA D####.# car amplifiers have balanced inputs?
Do the PA D1000.1, 2000.2, 4000.4, and 5000.5 car amplifiers have balanced inputs?
I'm currently planning an install in a car whose head unit outputs balanced signals. I want to ensure compatibility without having to install a line out converter (LOC) in between the head and the amp to convert the signal from balanced to unbalanced. I'd prefer to connect directly from the head unit to the amplifier without any additional electronics.
Answers
  • nbrowsernbrowser Posts: 7,914
    um one question, I've been involved with car audio for several years and to this date I've never ever seen a head unit with balanced pre-outs mainly because they take up way too much space for the mobile environment. Could you possibly post what head unit you have?
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
  • lightman1lightman1 Posts: 9,441
    It might be a DIN port. Alpine, Kenwood and some older Clarion head units had them.
    Remember those, Ken? Good times.
  • nguyendotnguyendot Posts: 3,583
    Line out converter? Wouldn't your head unit just have RCA "line out" already?
    We typically used a LOC for speaker level to RCA conversion, which has terrible quality.
    Main Surround -
    lightman1 wrote: »
    Russ....I do remember those days! Still wasn't a balanced connection either as the signal was low level just as with the good old fashioned RCA jacks that every head unit manufacturer went with.
    edited April 2016
    I built many a system back in the 80s-90s. My how times have changed.
    edited April 2016
    nbrowser wrote: »
    lightman1 wrote: »
  • I remember what you are talking about Russ. My Concord had the same type of connector. It was smaller than a balanced connection plug and for the life of me cannot remember what it was called. I installed a Kenwood amp that had RCA inputs so had the actual cable modified to switch over to the RCA. A friend at an installers did the modification but only took about ten minutes so could not have been anything major.
  • NightfallNightfall Posts: 7,452
    Rockford Fosgate RFX8250 with 8v balanced outs
    Eclipse CD8053 has 16v balanced outs
    http://www.bimmerforums.com/forum/showthread.php?1027866-FS-Eclipse-CD8053-HU-Rare-deck-16V-balanced-outputs-PEQ-Active-Xover-etc
    afterburnt wrote: »
    S.O.B.!!! There again, it's been a while.
    The old style DIN connectors had all the info in one cord. Signal, remote switch, etc.
    Kinda like an HDMI today.
  • nbrowser wrote: »
    The head unit is an OEM stereo (technically, CiC) for a BMW. The pre-amplifier signals are balanced. If you want to tap into these signals, you have to have an amplifier with balanced inputs.
    edited April 2016
    What make and model Bimmer? I-drive? Early 2000s touch screen?
  • Lots of posts but no one offering any real pertinent information relative to the question. If you don't have any actual knowledge about these amps and whether they accept balanced signals, please don't clutter up the thread. Thx.
    So, again, do the following amplifiers have balanced inputs?
    PA D1000.1
    PA D2000.2
    PA D4004.4
    PA D5000.5
    Thanks in advance!
    Just trying to get a baseline on the head unit. Have a nice evening.
    To answer the original question, nope, no balanced inputs on any of those amps. That said this might be the best time to refer the installation of aftermarket gear in to that car to a professional installer.
  • Nightfall wrote: »
    Yeah. Thx. I saw that. It doesn't seem to mention anything about the Polk amps though. There's also another thread on Bimmerpost with a list. However, again, no mention of the Polks :/
Howdy, Stranger!
