EX Series II 2560 into book shelf speakers
I found my old EX Series II 6.5" component speakers. If I made a cabinet for them, where can I go to determine what the cabinet size should be?
Those with a 10" Momo sub should be a pretty sweet PC speaker setup.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Those speakers were designed as infinite baffle types, meaning they don't require a specific enclosure volume behind them to sound best. You can make whatever internal volume you choose, just make it as large as possible to avoid reducing bass performance.
    Most of the time the tweeters in car speakers are a bit overly bright if placed at ear level, but have a flatter response if heard off axis. Just a thought.
