I have been ripping all of my CD's on an old PC it is a DVD drive but
with EAC it usually reports back 100 to 99% rips. Should I be using something more up to date to get the best quality rips?
  • afterburnt
    afterburnt Posts: 7,892
    I would go back and start ripping everything again if "bit perfect" matters that much.
    tonyb Posts: 32,906
    Are you ripping in a Lossless format ?
    billbillw Posts: 6,189
    edited March 2016
    Audio ripping hasn't improved at all since the early 2000s. Pretty much any dvd drive will rip audio perfect if you have the correct settings. EAC has some settings that aren't set by default. It will slow it down big time, but it will guarantee perfect rips (as long as the disc isn't flawed).
    If you want, this website has a guide on making truly perfect rips with EAC.
    http://xunside.info/eac/
    For rig details, see my profile. Nothing here anymore...
  • afterburnt
    tonyb Posts: 32,906
    Have any error correction controls on ? It will take longer to rip them with them on, but it will give you a better recording.
    heiney9 Posts: 25,081
    Bit perfect does matter. I use DB Poweramp. It's not free, but it's inexpensive.
  • RamZet
    RamZet Posts: 792
    For some reason I ripped a bunch of CDs this week, even though they are on my Murfie account...
    Anyway, I use Windows Media player and under settings I set it to .WAV. They have FLAC and other stuff in there but I feel CDs should only be ripped at .WAV.
    B&W CM9Classé Sigma
  • afterburnt
    tonyb Posts: 32,906
    afterburnt wrote: »
    Why only WAV?
    Because some claim WAV produces the best recording due mostly to it's uncompressed file. Where as other formats compress first, then uncompress, which saves space too over WAV. Personally I've been hard pressed to tell the difference much at all.
  • Nightfall
    Nightfall Posts: 10,071
    I wonder how large (file size) is an album in 192/24 WAV?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • RamZet
    RamZet Posts: 792
    I RIP CDs at their native settings.
    16bit/44.1kHz and Wav.
    I believe this is what a CD produces, so it make sense to copy them at that.
    B&W CM9Classé Sigma
  • tophatjohnny
    tophatjohnny Posts: 4,164
    It does matter what level of gear you do your listening on as well. So okay, rip away 16 bit/44.1 Hz all you like. I bump mine all up to 48000Hz and am loving the results. Have I A-B'd it with several cd's?? You bet I have. Carry on, and space on my drives is not an issue. All about the end result.
