Avengers blu ray skips and pauses
Mr. Sharpe
At thought it was a used movie but I got a new copy today and it does the same thing, almost like it's steaming the movie, what's th e deal? Very annoying. Player is turned on and off daily with my power conditoner.
Using a marantz UD7007. Please help
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
I expected you to say it's with a Panasonic player...which mine does on far too many discs...
If perfectly clean new disc, suspect dirty lens maybe?
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
Check the manufacturer's website to see if there is a firmware update for your player. Sometimes newer discs have encoding changes that require firmware updates in players.Proud and loyal citizen of the Digital Domain and Solid State Country!
I've read that Panasonic players do that.
I need to, I'll look into doing that. Thanks a bunchHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Parasound HCA -1500a Amplifier -
Age of Ultron played through without an issue.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Take it back, I've gotten a few bum discs along the way.HT SYSTEM-
lsi 9's -
are you Sure it wasn't the HULK making it skip?2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
DarqueKnight wrote: »Check the manufacturer's website to see if there is a firmware update for your player. Sometimes newer discs have encoding changes that require firmware updates in players.
I haven't gotten around to it yet. I found where I can put in my serial and I need to do it sometime. we watched the movie the other day and the pauses were clumped together about 5 at a time roughly 20 minutes apart. it's annoying. but the first time we watched it got so bad and completely stopped playing.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
What he said^^^^. This happens all the time with new discs if you don't check for updates.
Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I know of someone who had a similar issue with the Dredd bluray, and he's using a
(older) Pioneer BDP-09FD. The disc played once or twice and will not even load anymore. And every other BD he owns is fine.
Not sure if a firmware update would be in order, he asked me and I told him give it a shot - or just buy an Oppo... LOLSo, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
yes do this I have a used BR player I bought here Pioneer Elite BDP-51 and it started skipping and not playing new BR movies.(DVD's played fine) I didn't expect it to still be supported yet I went to the Pioneer website after checking my Firmware number and low and behold there was a new firmware upgrade and it even listed the movies that were causing problems. With BR you need to check often get used to it it is the nature of the beast even if you are not having problems update those suckers.
That seems ridiculous to have to do... but on the other hand the picture is so sharp it's worth it. DVDs are so fuzzy now, I've slowly been buying bd's new and used:) worth every pennyHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
I checked the updates and upgrades on marantz.com and they have an update for all their receivers, none for the blu ray player.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
