Polk SDA 2 Issue
pongshi
I was going to buy a pair of Polk SDA 2 for a good price but ran into a snag. It seems that the dimension array was only working in one speaker. Do you know the probable cause of this might be?
Living Room
Parasound Model 2250v2 amplifier
Parasound P5 preamp
Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
Schiit Mani Phono Preamp for Turntable 2
Oppo UDP-205 CD/SACD USB and FLAC duties
Technics RS-1500US reel to reel
Polk SDA SRS (2nd Gen) fully modded
Parasound P5 preamp
On my SDA 2A's I ran into this issue (a little while after I bought them). I pulled the passive and it just happened to be the wire going to the dimensional crossover came off. It was an easy fix to be sure but I did use pliers to tighten the little buggers up...Remember, when you're running from something, you're running to something...-me
Living Room
Parasound P5 preamp
