Component mm6501 VS Coaxial mm651, sound clarity differences?
MMPolkerMMPolker Posts: 17
edited February 2016 in Car Audio & Electronics
I want to compare the sound quality between the mm6501 and mm651.
Are they both just as good? Do the midbass on the component or coaxial have differences?
  • I have not compared them directly, but the components should have a stronger mid cone since their is not a hole in the middle of it. But the biggest difference is being able mount the tweeter in a better then factory location.
    The front speaker location for my Freestar is at my knee. Having the tweeters up on the little triangle panel by the window, really raises where the sound is coming from and can also be aimed a lot better.
  • codycatalistcodycatalist Posts: 1,276
    I would go with components personally. I like the sound of separation.
    Some do not like multiple layers of speakers and keep it to a minimum then choose Coaxial. It is subjective.
    Living room
    Mains: SDA 2B Studio
    Lows: Velodyne CHT12
    Power: Yamaha AV34
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: Paradigm 90p
    Lows: Pioneer SW-8Mk2
    Power: Marantz SR7000
    CDP: Technics SL-PD688
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
Howdy, Stranger!
