Speaker Wire With plugins to connect Denon AVR-X1200W to Polk Monitor 60
bryanschmiedele
I bought a new Denon AVR-X1200W and am almost finished rebuilding my Home Theatre system. I have all Polk Speakers. I will soon be in the market to upgrade my Polks, so I want to be able to pretty easily plug and unplug speakers.
To this end I bought one of these:
Affinity™ Premium 14AWG Braided Speaker Wire with Gold Plated Banana Plug Connectors - 10ft
But it appears to me that these do not fit the Polks. Or I am not understanding something. Or maybe I am an idiot. Don't know which.
I *think* I now understand that there are various type of Banana Plugs. I also *think* that the Polks are five way binding?
I would really really like to buy something that has the banana plugs already built in.
Does anyone have any idea what I can get?
Welcome to the forum bryan! Stick around and participate.
Don't worry, I think many of us have once been in the same boat. I didn't realize you could remove those plugs at first either many years ago...
Alternatively, you should be able to fully unscrew the binding post lugs and then fit the banana plug in vertically where you would insert the wire. Sometimes I prefer this method as it puts less pressure on the speaker wire where the banana plug ends (especially since the biding posts on polks cause the banana plugs to point upwards at an angle...)
Either way, good luck!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Terrible advice ^^^. Sorry man, inserting banana plugs into the post hole meant for wire is exactly how PFB snapped a post. That's not what that hole is for. The previous poster had it right.
If I read your answer wrong, then apologies.
lsi 9's -
Use spades at the speaker posts if you are concerned with the speaker cable angle using bananas. I prefer spades at the speaker myself.2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
Bryan,
Is this what you bought ?
http://www.amazon.com/Monoprice-AffinityTM-Premium-Braided-Connectors/dp/B015YN6G9G
Dude, your Polks deserve better than 12 buck speaker cables, seriously.HT SYSTEM-
lsi 9's -
@bryanschmiedele, those cables will do fine. Plenty of time to explore better cables later. Use a fingernail or knife to get under edge of the little plastic plugs and pull out.
Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Schiit Yggy * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Whoa, did that just happen? Interesting.
+1 solid adviceHome Theater
