Removing rt series tweeter from plastic trim
rooftop59
Hey all,
Simple question: how do you remove the tweeter from an rt series (rt25 et al) from the plastic trim? I am assuming you can, but don't want to damage anything.
Thx!
Thx!
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer
Place a thick bladed screwdriver along the clip on the back, twist that clip open just a bit and push from the front and they will pop out the back of the bezel.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I'll try that. Thx!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
