Anyone upgrade their storage on the PS4 yet?
Went to play Mad Max free from Redbox for a day. Would not let me because I am out of storage 500gb. Finding out now that one game can use 55gb just to play (GTA5). System requires almost 76gb for updates and such. Easy to see why my 500 GB system is tapped out. Sad day for Sony when they knew this would happen! Want to upgrade to 4TB or 6 TB so I can be done with this nonsense for a long while. Thanks. D
MIT Magnum MH-750, Monster HTS 5100MKII, Mitsubishi rear projection 73, PS4, PSW505 , Sunfire Signature Grand 425 x 4, RTi12, FXiA6, CSiA6, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05
“Why did you get married if you wanted big speakers?”
  • nbrowsernbrowser Posts: 7,550
    Should be able to upgrade easily, I put a 2TB drive into one of my PS3s when I had a drive failure. Surprisingly Sony makes it deadly easy to do a HD upgrade. Just use our god friend Google to find out how and actually, how big a drive you can go. It's a easy process but do follow directions, actually should even be instructions in the manual as well.
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
  • quickr1quickr1 Posts: 370
    There is a kit on Amazon with everything you need to put in a 2tb hard drive. I debated doing it b4 I loaded BO3. It is around 130 bucks.
  • Mikey081057Mikey081057 Posts: 4,968
    Probably best to go with a sshd Solid State Hybrid Drive.... Much faster...only a few bucks more. There are plenty of instructions on how to backup and restore your O/S and .data on your existing PS4. 5400 RPM drives are slow and a 4TB 5400 RPM drive will really get slow as it ages with more data stored on it.
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7702 | Sunfire TGA-7401 | Oppo BDP-103D | Sony PS4 | Directv Genie HD DVR | Samsung 64" Plasma | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A23 x2 Amps Parsound Halo A21 Amp & P5 Pre | Marantz SR5011 AVR | Usher Dancer Mini-x DMD's| Usher BE-616 Center|KEF T100 Surrounds | SVS SB2000 Sub |Oppo UDP 203 | MIT Shotgun S3's | Marantz SA8004 SACD | Bluesound Node 2 | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | HP Elite Slice PC |Samsung 50" SUHD TV
    Patio Polk Atrium 8's |Marantz 2252B |
    Office Bluesound Node | Audioengine P4 | Peachtree Nova 125SE |
    Closet | SDA SRS 2.3's | Monitor 5B's Yamaha M80 | Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2385
  • RamZetRamZet Posts: 776
    Can you connect any old USB 3.0 HDD to it like XboxOne?
Howdy, Stranger!
