Canare 4S11 Bi-Wire Speaker Cable
Irrenhaus
How good are this ones. I will be going from C2G / Cables To Go 29176 12 AWG Velocity Speaker Cable to this ones. This will be for the RTi12s for HT duty.
http://www.amazon.com/Single-Bi-Wire-Speaker-Bananas-Locking/dp/B00SPVJXKE/ref=sr_1_11?ie=UTF8&qid=1453675763&sr=8-11&keywords=Canare+speaker+cables
Cheers
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Buy it as raw wire and do it up yourself with the added benefit of getting the exact length you need. Only $1.35 per foot
https://www.bluejeanscable.com/store/speaker/
Because I am The Pumpkinking
Have Inc.also carries black jacket and Douglas Connection is also a good source but Doug only carries gray. I agree buy bulk do yourself.
I used the Canare, and have now switched to Furez 10/2 from Doug. The Furez is more neutral to my ears.Home Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »I used the Canare, and have now switched to Furez 10/2 from Doug. The Furez is more neutral to my ears.
What would you call the Canare? Bright? Warm? Dark?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
A bit on the bright sideHome Theater/2 Channel:
pumpkinman wrote: »Buy it as raw wire and do it up yourself with the added benefit of getting the exact length you need. Only $1.35 per foot
Thanks for the advice. I will look into it.
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
westmassguy wrote: »westmassguy wrote: »I used the Canare, and have now switched to Furez 10/2 from Doug. The Furez is more neutral to my ears.
I would agree with this also, may not be the best match with RTI speakers. Unless you like that type of sound of course. Kimber cable would be a better match imho, or Analysis plus. If you can find a used pair of Reality cables, usually for around 100 bucks, those would gell well with the rti's also.HT SYSTEM-
