Connect sub to B&K PT3
footwedge
Per the below links, i believe all I need to do is connect a sub cable from either the PT3 mono l&r or the sub jack and connect to the sb1000 lfe. Is this correct? I will be using the b&k 200.2 connected to LSI7s.
Sometimes, no all the time, I try to make this to difficult.
http://www.manualslib.com/manual/14259/BAndk-Pt-3-Series-Ii.html?page=13#manual
https://system.na1.netsuite.com/core/media/media.nl?id=69175&c=3634088&h=a2a627c5bd0810a8a24e&_xt=.pdf&ck=uDlMngYDAhxZe3oV&vid=uDlMngYDAiNZe0qK&cktime=131840&cart=59510&gc=clear&ext=F
Yeahupers that's all. The pt3 crossover is set at 80hz.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
