Stupid is as Stupid Does - A little Bottlehead Foreplay - Dodd
Well - following my listen with the Rumba, I'm going to have to sheepishly admit that I made a bit of a boo-boo. Well, more than a bit of a small boo-boo, I guess... So long story short, I hooked the Dodd MLP back up after rolling in a nos quad of Amperex 12AX7's to give them a listen and forgot to hook up my source components before I powered it up.
Yikes! A quick pop and spark and I unhooked it immediately but I definitely popped something. Little black thing is cracked that I can see for sure. Soo - I'll be giving Charlie Cocci a call I guess to see if he'll have a look at it for me... but I needed something in the mean time. Enter the Bottlehead Foreplay below:
Came with the major upgrades already installed, DC pre-heat, Anticipation, gold RCA's, upgraded caps, etc. I have to say, for the money, (barely more than the kit used to sell for without the upgrades), I was pretty surprised when it arrived.
Hooked it up to the Dodd 50W, and the new SDA2BTL's that I recently built up, and I'm pretty surprised by the sound too. It has a nice black background overall, though the stepped attenuators are really crackly when moving between steps, I guess that's par for the course with that upgrade. Overall - it'll definitely do until I get the Dodd back. It's no Dodd, don't get me wrong, but for a $200 tube preamp, I'm pretty shocked at it for now!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
    SCompRacer Posts: 9,119
    Sorry to hear about the Dodd. Bottlehead is known for great circuit design. They have some higher end 300B tube pre amp kits like the BeePre.
    I have a Bottlehead Eros phono stage that punches way above its weight. Quiet too, low distortion. They also offer an impressive Tube Phono they build for $7500.
    F1nut Posts: 51,874
    Post a pic, might be able to tell you what it is and how to fix it yourself.
  • MrBuhl
    MrBuhl Posts: 2,419
    Thanks Jesse, going out of town tonight but I will post asap.
    @SCompRacer yes, I was very surprised at how quiet the design is, I can imagine their more pricey offerings are very good indeed if this one is that good at it's price point!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    @F1nut - here's a pic (stolen from blueMD's post) for now, I don't remember exactly which one of the set - but it's definitely one of the black half cylinder shaped pieces pointed out by the lighting bolt. Cracked right through it.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited January 2016
    That's a transistor. There are two types on that internal board:
    KSP94 336 (two of them, the one you're pointing to and the one below it)
    KSP44 339 (the other 4)
  • Curious if you were able to repair and get back in service?
  • MrBuhl
    MrBuhl Posts: 2,419
    I have not tackled it at all yet... Sadly! I have it on my list of things to do, but life (and new turntables) keep getting in the way LOL. I have it pulled from that system and ready to either have a go at or call Charlie Cocci, but have done neither so far.
    Partly I'm a little too intimidated to get started!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • Totally understand. Without access to a schematic and/or test point readings, it's pretty much an exercise in futility. Please let me know if you have any success should you send it to Mr. Cocci. Good luck!
