WTB - PSW450 Amp
rshores84
So the other day my PSW-450 started turning itself off and on randomly as I listened to music and after talking with technical support they said it could be the amplifier going back and suggested I check the forums to see if anyone had spares or to find somone with a blown until I could pick apart, so fingers crossed.
Haven't seen that model around here in a long time. You can try Parts Express to see if they have an amp compatible.
Other than that, I'd say you just may have a good excuse to upgrade the sub.HT SYSTEM-
lsi 9's -
I did go ahead and upgrade to a PSW-505, but figured I'd still try to fix it and use it in another room possibly.
I just found this thread...I have a extra amp, driver, and speaker grille. You still need it?
