Denon DA-500 DAC issue...
In the respect that it doesn't work. The red light flashes above the respective channels when the button is pushed but no sound and the light keeps flashing. Ideas??
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • starkiller
    starkiller Posts: 2,723
    nobody??
    tonyb Posts: 32,906
    Did you have a power outage ? Sometimes this happens if you have a power surge. Unplug the unit for a good hour and plug back in.
    Has anything else changed from when it was working to now ?
  • starkiller
    No power outage. Have it on a switched outlet so shall i still inplug it? Nothing changed.
    tonyb Posts: 32,906
    edited January 2016
    Yeah, unplug it and wait about an hour and plug it back in. A power surge could have happened while you were out too. I'd also take it off the switched outlet and plug it directly into the wall when plugging it back in.
    If that doesn't help, pop the top and see what you can see. Look for any fuses, burnt boards, lose wires, or leaky/corroded caps.
  • skrol
    skrol Posts: 3,337
    I have no knowledge of the unit but is there a reset procedure?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • starkiller
    Not that I've been able to find...will also try out tonyb's idea tomorrow...
