Sub placement Question
I bought SVS on the forum awhile back and love it, although I have no idea what model it is. Also, there are no feet or spikes on the bottom. Heres my dumb Q - can I flip this thing 90 degrees due it is so tall. Here are pics
  • classic carl
    classic carl Posts: 648
    edited December 2015
    According to the label on the back, that appears to be an Epik sub, not a SVS. If it's too tall for you, lay it on it's side and see if the sound is to your liking. You can always install spikes or feet if you want.
    Main System:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8 & FB210 ~ Martin Logan Dynamo ~ Teac R-919X ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater:
    Vizio V585-H11 ~ Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Marantz DV6001 ~ EPI M90 ~ Polk Audio RT35i ~ CS400i ~ (2) Polk Audio PSW450
