do you really need a dedicated cable.
leftwinger57
When I 1st bought my avr H/T set-up I was told I needed a sub woofer cable. Looked like a cable w/ RCA ends on it Monster Cable in fact. Is there any difference between said marketed sub woofer cables and a decent RCA cable to use as a sub cable ? Marketing ploy, reality or myth. I don't have a RCA cable long enough for a test so I might as well ask you dudes. I just looked at my Sony processor /pre and it does have dual subwoofer ports so if a sub falls on me I might use it.
Some will say yes, some will say no. I fall into the no camp. Any rca cable will do imho. Matter of fact, I've gotten better performance using a regular RCA than a dedicated sub cable.HT SYSTEM-
lsi 9's -
Well.... I used dedicated sub cables before and noticed a difference.....
And the one I would suggest isnt super pricey either..
This is what I had.... I'm going to be buying some more here soon for my DIY sub...
http://www.audioadvisor.com/prodinfo.asp?number=AQBTIISUB"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Learn something new every day. Until now I have never heard of a dedicated sub woofer cable. Is it optimized to pass low frequencies?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I believe so... I went from a Audioquest Sidewinder RCA to the Black Thunder and there was a REMARKABLY obvious difference in the bass......"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I use a directional Acoustic Research dedicated sub cable. At the sub end there is a ferrite ball. In the past I've used non sub cables but with a different sub so I can't tell you if it makes a difference. It's an rca cable just like interconnects and a digital coax. Could they be made slightly different, sure. I've never taken them apart to compare.
When I had my anti mode I used 1 meter diamond backs to the antimode, then sub cables to the subs. Made no sense to buy 2 sub cables to make a 1 meter run. Plus I've never seen a 1 meter sub cable. Long story short I think a good quality shielded RCA is all that matters. I am a cable believer, but I don't feel sub cables matter as much. I use a energy conneseur sub cable. They are maybe 40 bucks for 5 meters, good quality and have rf stoppers at one end.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Any long RCA interconnect needs a good cable!
What's long? Significantly more than 10 feet (3 meters).
What is the good part? Low end-to-end resistance of the shield.
Why? It reduces leakage current back-ground noise.
An example and explanation: The Blue Jeans Cable LC-1
http://www.bluejeanscable.com/store/subwoofer/index.htm
http://www.bluejeanscable.com/store/subwoofer/LC1-design-notes.htm -
Correct ^^^^^ depending on the wire inside that cableEndersShadow wrote: »
well for one you went from bottom of the stack to upper in wire quality
sidewinder is "long grain copper" Black thunder is the same as King Cobra "perfect surface +"
Any cable that is not "dedicated" to its job, is a "slacker" and should be fired!Currently orbiting Bowie's Blackstar.!
I went with a 30' RCA interconnect from Blue Jeans cable. When I added a second sub, I had to daisy chain the two and I used a Monster Cable that I had on hand. I can't tell a difference between the output of the two subs. That said, I've noticed a difference between IC's from source to pre and pre to amp which is why I spent the extra bucks to get something better than a generic RCA cable for my subs.____________________________________________________________ polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS SVS PB13 Ultra x 2Pass Labs X1, Marantz 7704, Sunfire Signature Cinema Grande 400, ADCOM 7807, Panasonic UB420, Sony SCD-C333ES, EPSON Pro Cinema 6050
