Need Advice On Hook-Up Wire
Advice needed on some decent (budget) hook-up wire to have around while working on my Polk speaker projects. The NTE wire I was looking at comes in two voltages with slightly different specs. What would be the best choice for the aforementioned usage? The 600v wire is a little cheaper and I thought it would be the other way around. Thanks, Don
300v 16awg tin plated copper, 16 strand, 6 amp
600v 16awg tin plated copper, 26 strand, 15 amp
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
    pitdogg2 Posts: 24,481
    Both will be fine get the one that best fits your budget
  • stogie
    stogie Posts: 230
    thanks pitdogg2
    TT: Technics SL-MA1
