Controlling Output to Sub-woofer
Irrenhaus
Irrenhaus Posts: 1,082
Hi All
Simple question.
I have the sub woofer pulling double duty as HT and music. For HT the sub woofer is connected to the AVR via LFE channel.
For stereo the sub woofer is connected via the loop on the Parasound amplifier. The sub has two separate inputs. The problem I have is that the Cary Preamp has a a bit of a high gain output so when I use the sub for music I have to manually lower the volume of the sub on the back of the unit.
I was thinking if I can use one of this instead.
http://www.mcmelectronics.com/product/MCM-CUSTOM-AUDIO-50-8394-/50-8394
Or a passive one also.
http://www.amazon.com/Schiit-Audio-SCH-13-Passive-Preamp/dp/B00K6Q2A4C/ref=sr_1_60?ie=UTF8&qid=1438452122&sr=8-60&keywords=Line+Level+Volume+Control
It will place in between the amp and the sub.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Irrenhaus
    Hi
    I just went ahead an order this one. Will be here tomorrow if I don't like it I can returned.
    http://schiit.com/products/sys
    Cheers
  • Irrenhaus
    So it arrive today. Is a small unit. Testing will be later on the day.
  • Polkie2009
    Polkie2009 Posts: 3,834
    I love the fact that it's made in the U.S.A. . :)
  • Irrenhaus
    Well so far is dead quiet. Very nice and working great.
  • PolkieMan
    PolkieMan Posts: 2,446
    I don't use subs for music only movies nice little button on the front panel called Pure Audio. During movies I don't like send all those explosions and noise to my front mains so I Xover at 90 to the two psw 505
  • Irrenhaus
    PolkieMan wrote: »
    I see. Is that in my case the Linn's and the Usher bookies don't go that deep. I do have the SDA 1C but those still need to be restored.
    Cheers
  • PolkieMan
    Sometime I think the 1C's have more bass than the 2.3tls :o
    Irrenhaus wrote: »
    PolkieMan wrote: »
    Cheers
  • Irrenhaus
    DSkip wrote: »
    Have you played around with placement? I've found with the Mini X that if they are free floating in the room so to speak, you're going to have some deficiency in the midbass regions. If you support them by placing them near a side wall, namely within 9" or so to the side, you're going to get much better support in the lower regions.
    Yes is like any bussiness. Location, location, location.
    Cheers
    Rey
