Woodbourne not powering up and don't have remote.
My new Woodbourne stopped powering up after 2 weeks. I can see the orange standby light is on but dim. BTW, I lost the remote during transport so I was only able to operate it via the front switches - it worked fine when it did. How should I go about troubleshooting it now. I have tried basic diagnostics, inc. keeping it unplugged for days, holding on various key combinations on the front panel, etc. I think it appears to be a power on problem. So I'm thinking some reset might work. Will having a remote help?
I cannot return it as I bought it at Frys and now I'm in Sydney, Australia. I'm reasonably technical so happy to follow advice in troubleshooting and repair anything electronic.
Thanks.
Thanks.
Answers
Hello,
Welcome to Polk's forum. What is the operating voltage and frequency in Australia? It would be best to contact Polk's CS department via email to: polkcs@polkaudio.com and explain what is happening.
Regards, Ken -
Hi Ken,
Thanks for your comment. Voltage/frequency are 240/50. But the Woodbourne supports both 110/240. It did work for a period of 3+ weeks on 240. I have also tried 110V as I have that at home.
I have contacted Polk customer support but no response from them other than to say a ticket has been created. I have also left messages. I must say the Polk customer support experience has been very poor for me so far. I will try sending an email again.
Wijay -
Thanks for the explanation. Polk's CS will return to work tomorrow (Monday on this side of the globe) and will answer your email as quickly as possible. I'll send a copy of this thread to Polk's CS representatives directly, perhaps that will speed things up a bit.
Regards, Ken -
Hello Wiijay,
It might be best to contact Polk directly at: Ken.Carter@soundunited.com
He's aware of your situation.
Cheers, Ken -
Hello,
Here is the contact information for the Australian importers:
International Dynamics
email: internationaldynamics.com.au
129 Palmer St
Richmond VIC 3121
Australia
Phone: 03 9426 3600
Fax: 03 9426 3633 -
any update on this as mine isn't powering up and I'm in the US.
Hello,
Welcome to Polk's forum. It would be best to contact Polk at 1-800-377-7655 select option 1 when prompted. Have the serial number and date/place of purchase handy when you call.
Regards, Ken -
americaneon wrote: »any update on this as mine isn't powering up and I'm in the US.
Is it not powering on, or is there no sound?
