CS245i Center speaker
aboey
aboey Posts: 1
edited February 27 in Clubhouse Archives
Anyone has the CS245i? I just got them for $150. It sounds pretty good, but there is some "clicking" or scratchy sounds coming out when playing certain VCDs.
Could it be that I am sending too much power to the center speaker with my amp? Should I adjust the home theatre setting, like from "large" to "normal"?
Your help is deeply appreciated.
Post edited by RyanC_Masimo on
  • TroyD
    TroyD Posts: 13,077
    edited July 2001
    I had a 245i with no problems. I doubt that you were sending it too much power though. Additionally, I would leave it set to small. I would check with Polk customer service. I am sure they could help you out.
    Troy
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited July 2001
    .....anxiously waiting the outcome.....
    Cheers,
    Russ
  • TroyD
    TroyD Posts: 13,077
    edited July 2001
    I can't stand the excitement!
    Troy
  • TroyD
    TroyD Posts: 13,077
    edited July 2001
    and I had been looking forward to this all weekend.
    Troy
