Free amps
Was parking my car, and saw a couple of amps sitting in a box behind the dumpsters, power distro blocks and ground wires hanging out gave it away. Walked up for a look, there Sat a JL E100 AND E6450M. A little dusty, but cleaned right up, clean and tidy inside as well. There are some screws missing, and I have yet to test them. I will hook them up this weekend, and give them a whirl. Of they seem to work well, I'll buy the screws and eventually use them. If they don't, I will have an ET friend see if he can sort them out, or run them over to the Frys and see if they can do anything at the repair counter.I think the 6 channel would do well in the zuk with some type R coax, type G coax, and a 6 or 8 inch sub(sealed box probably)
  • seabeerob213
    seabeerob213 Posts: 1,840
    Anyone know these amps?
    tonyb Posts: 32,906
    Not me, but I'd hook them up to garbage speakers first....has to be a reason the amps were tossed.
  • seabeerob213
    None of my car speakers are anything special, just clearance rack middle line old arse Kenwood, or pioneer. Figured I'll just test the channels 2 at a time with the rears in the escort. If they all work, it will power a set of 4 coax alpines, 2 type r, 2 type g, all 5.25. And if mono works, I think a 6-8 inch sub is in order. All should wire up nice in the samurai.Lots of work to get to there though. No user serviceable parts on these BTW.
