Headphone Amp vs. Eastern Electric Minimax CDP Tube Output
MrBuhl
MrBuhl Posts: 2,419
edited June 2015 in Headphones
HI guys - been shopping around for headphone amps lately, and I have a question.
My new Eastern Electric Minimax Tube CDP has a very well reviewed tube headphone output at least 6 Moons dug it - so I'm wondering, would I gain a lot by getting a separate amp vs just continuing to use the Minimax?
I have Polk Ultrafocus 8000's and the Phillips FIdelio X1's I just picked up for cans if that helps. I've been looking to pickup one of the following used amps (trying to stay under $300):
Schiit Lyr
Schiit Valhalla
Woo Wa3
Little Dot III
Thanks for your thoughts & advice!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    Hmmm - thats an interesting thought indeed @nbrowser, so you think the tube stage in the Minimax is probably good enough for my purposes. Makes it easier since the SS Asgard is a bit more on the reasonable side as well I think.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
