CSiA6 Q&A please clarify
This is from the Polk product page:
>>MikeG
· 2 months ago
I have monitor 70s up front along with the CS2. Would this be a worth-while upgrade to the center channel? Will it timbre match with the monitor 70s?
Polk_Support_Ken
· 2 months ago
Yes, they are matched to each other.<<
This is the first time that I have seen that the CSiA6 and Monitor 70's are matched. Is this true?
Bruce
  • vmaxer
    vmaxer Posts: 5,116
    la2vegas wrote: »
    No one questions Ken. No one.
    Polk has another Ken...confusing,,,yes. :s
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • afterburnt
    afterburnt Posts: 7,892
    So "Polk_Support_Ken" is wrong?
    F1nut Posts: 49,798
    I never looked into, but it is possible the two series share the same tweeter. That said, I'd rather have all the same series in my HT rig, at least the front three.
    gudnoyez Posts: 8,066
    RtiA5 buy one get one free you should take advantage of that, a good match for your CsiA6, for that perfect front stage. I know you knew that the 70's weren't timbre matched to your new center but the A5's are at half price you should consider them.
  • afterburnt
    gudnoyez wrote: »
    gudnoyez I see buy one get half off the second one. Where do you see buy one get one free?
    My bad 50% off the second speaker that's still a deal.
  • afterburnt
    Thanks for the heads up maybe I can catch them on FF deal down the road. I am tapped out right now. I sure do like this csia6 even though it's not dialed in yet. The improvement over cs20 is immediately obvious.
