Replacement Amp Board on PSW110?
I have a PSW110 that seems to be damaged (started making cracking sounds at low volumes). It is out of warranty.
I emailed Polk CS and quickly got back a helpful reply suggesting that the Amp board was faulty and that I could purchase a replacement one for $100 + tax and shipping. The representative gave me a part # as well: RF1137-2.
I've replied several times for more information but never received another reply, so trying here. My questions are: is this the type of repair I can do at home? And is there an online store to buy the replacement parts?
  • stevepstevep Posts: 48
    You can swap the board at home but repairing the actual amplifier board yourself is beyond the scope of most individuals. You can order the replacement from Polk Customer Service (1-800-377-7655) or from The Speaker Exchange http://reconingspeakers.com/product/polk-psw110-amplifier-assembly/
    Polk replaced mine under warranty back in 2012 but the replacement is now also failing so unless they have made design changes you can expect future failures.
  • atorgatorg Posts: 2
    I called Polk and they actually sent me the part for free even though I was slightly out of warranty. Replacing the part was straightforward and the sub works like new. Another Polk CS success story!
  • tonybtonyb Posts: 29,744
    You can probably pick up a whole PSW 110 on the used market for under 100 bucks. Personally, for the 100 bucks, I'd look at other subs or at least move up to the 505.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1430 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • spexspex Posts: 2
    we stock this amp if you need it. www.speakerex.com
    Even at Speakerex, the amp is 100+ bucks, you can buy a whole other used sub for that price....possibly even better. Throw in 50 bucks and you might come away with a 505 on the used markets.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1430 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
  • stevep wrote: »
    Replying to a 3 year old post...but just to help anyone who has this problem. If you know how to solder and have a Steady Hand then you can fix this issue for under $5.00 buy some capacitors 63V 47UF you will need two. You will also need thermal paste and a soldering iron and rosin core solder and a toothpick.
    Check out this blog and follow it.
    http://hesiod.blogspot.com/2016/01/how-to-fix-humming-on-polk-psw111.html?m=1
    Tips
    1.note the old capacitors and the orientation of the polarity.
    2. Twist off the old capacitors with needle-nose or tweezers twist left and right or keep going in one Direction until the capacitor breaks off from the solder joint.
    3. Heat up the backside joint and pull off the top side joint with some tweezers or needle nose pliers to remove the leftover capacitor wire/joint.
    4. Get your solder iron and heat up the back side while putting pressure with a tooth pick on the top side. Once the solder melts, the toothpick will push through, wait a couple seconds for the solder to cool down and pull the tooth pick out and you will have a nice clean hole.
    4. Install your new capacitor & clip off the excess.
    5. Use thermal paste and apply where old thermal paste was.
    6. Enjoy your repaired subwoofer.
  • F1nutF1nut Posts: 40,373
    Ummm.....simply desolder the original caps using a solder sucker to remove the solder leaving the holes nice and clean. That's a lot safer than trying rip a cap off via a method which could result in the cap leaking out.
  • F1nut wrote: »
    You are correct.
    I apologize I should have added this in my post.
    - try this method at your own risk-
    - it would be best use a de-solder tool
    - I didn't want to spend more $$ nor did I have the time.
    - I have used to twist off method many times on small capacitors do not try this on larger ones...if there is any residual voltage..it could harm you.
Howdy, Stranger!
