Wiring diagram for Polk Audio MM651
sink320
Hello, I need help wiring my speakers. I recently removed them for some mechanical work and now don't remember which way to wire them. What I mean is which wires from the crossover go to which terminals on the speaker? Thanks for any help as I don't want to mess them up.
Hello,
Welcome to Polk's forum. If you look at the crossover with the connections to the right the upper connections are for the tweeter, the next ones are for the mid/bass driver and the lower most are for the power amplifier. The area on the side under where these connections are made will have the polarity.
Regards, Ken
