Passive Radiator Repair
teamjhertz
teamjhertz Posts: 361
I have a passive radiator that needs repair. The cone is coming unglued from the spider in one spot on the radius. The spider appears to be fine with no tears. I am hoping that i can just add some new adhesive to repair. Any recommendations on what type of adhesive to use? I emailed the manufacturer as well and await their response.
  • teamjhertz
    A little two part epoxy and it is operational once again
    nooshinjohn Posts: 25,135
    I am so sorry I did not see this sooner, but it looks like you read my mind anyway. I hope you used it sparingly.
  • teamjhertz
    Thanks for the response. I did place a bead that was slightly wider than the original, but it looks like the spider moves freely. Time will tell how long it will last
