My First Crossover Rebuild
trav0810
I recently acquired a pair of monitor 5a parts (including cabinet). I have decided that since they are already in pieces, this would be a good time to get my feet wet. And this looks to be about as simple of a crossover as I could hope for.
2 caps, 2 resistors on each speaker. Due to an extremely limited budget, I will not be going TOTL on this at all. I will probably go with Jantzen or Erse. But first, I'm off to buy a fire extinguisher.
The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
Thorens TD320
Modified Carver C-1
Hey Travis
I did my Monitor 4's myself, I used some caps that were pretty big had a little trouble getting them inside, I ended up mounting the bigger caps on the inside but not back on the binding post. the only thing that got burnt was my finger Dave help me find a better binding post cup that fit without making the hole bigger for my 4's.
Have fun with it.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
When I did my 5's I was concerned about the new caps fitting on the board. Dave (westmassguy) suggested mounting the resistors on the bottom of the board so there would be room for the caps. It worked great.
That was a great idea. Thanks for passing it on. I might end up doing the sameThe difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
White Lightning Moonshine DIY Speaker Cables and Interconnects -
I have started gathering up some tools.
Thorens TD320
Modified Carver C-1
Now, can I get some recommendations on what solder to buy?The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Cardas Quad Eutectic. Best stuff on earthHome Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »Cardas Quad Eutectic. Best stuff on earth
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
That stuff isn't cheap!The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
RadioShack sells solder too if you just gotta have it today lol..
I'm ordering it...besides...RadioShak is closed on Sunday in New Tucky!The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
You can by it by the foot, don't have to buy the rollHome Theater/2 Channel:
Yes you do. You have to buy it by the roll because once you use it, you will never use anything else."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Agreed, but it is expensive, especially for a single project.
I buy it by the roll because I use so much of itHome Theater/2 Channel:
Well, this is my first project, but if I don't burn the house down, it shouldn't be my last. A good friend of mine on the forum here is sending me some of the Cardas to try out. I had ordered some old Kester 44 on the recommendation of a few other guys I know. It will be cool to compare the two.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Cardas rules. I think you'll be convinced once you try it.Home Theater/2 Channel:
My every day solder is Kester 44.
My "I am going to keep this forever and I want the best of the best for it" solder is the Cardas.
Can't go wrong with either but the Cardas is simply better."Some people find it easier to be conceited rather than correct."
westmassguy wrote: »...Best stuff on earth
Thnx, tony
Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
Cardas Quad is formulated for audio use. The blend is one of the best for audio quality on the market.
That's the short of it..."Some people find it easier to be conceited rather than correct."
Eutectic Solder is a blend of different metals. The combination has a lower melting point than conventional solder, so less heat required, less burned flux, safer for components. As ZLTFUL said, it was formulated exclusively for high-end audio circuitsHome Theater/2 Channel:
I LIKE the "...blend of different metals... ...lower melting point than conventional solder, so less heat required" stuff. I've made & repaired dozens of Pro patch & mic cords in addition to (some) home wishing for just such a product!!
Mille Grazie! [a thousand thank you(s)] for the tip.
TonySamsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
Years ago, I worked for Eutectic-Castolin in Flushing, NY. Those people are SERIOUS about their welding and soldering!TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
http://www.soniccraft.com/index.php/solder-lead-c-157_150_385
Quick question ... I usually buy the lead free Cardas TE... is it better to have the lead in the Quad?
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Cardas Eutectic, nothing else comes close.is it better to have the lead in the Quad?
IMO, yes. Look a little lead isn't going to hurt an adult. Now, if you solder with it all day, every day I can understand having a concern.
President of Club Polk -
I use it everyday, that would explain a lotHome Theater/2 Channel:
Thx, Tony
