Lfe Unfiltered input? psw404
jojomgee
The sub has the 2 refular "line in" rca inputs but has 3rd LFE unfiltered input.... should I be using the unfiltered?
And does connecting to the lfe unfiltered cancel out th x-over settings set in receiver?
Are you using the sub with an AVR receiver, or is this for a 2-channel preamp connection?
Use the LFE input on the sub from the subwoofer output from the AVR.
Then set the bass xover frequency on the AVR to 80Hz to start with and experiment from there to what sounds 'best' to you.
