FS Klipsch Epic CF-4 Speakers in Cherry - $1000
gmjungbluth
Hello all,
BTW - I have these posted on DC CL and the Klipsch Forum....
I have a pair of Klipsch Epic CF-4 speakers in Cherry for sale. The specs on them are below. These are very efficient two-way speakers with two 12" woofers and a 2" horn in each cabinet. At 44" tall and 19" deep, they're also pretty big. But still relatively easy to place - I have them in my smaller living room space right now.
This pair is in really great condition. The veneers are thick and beautiful, no pits or scratches.
And they sound great. With the two big woofers in each enclosure they get very low. I've been powering them off of my Lepai 2020+ and that's been plenty of power. Great dynamics. Better range and balance than the klipschorns I previously had. Definitely a different animal from my restored Monitor 7s. But the treble has a smoothness similar to the 7s that other Klipsch speakers ( KG4 and Klipschorns) that I have had lacked. The CF-4s do not exhibit the honk of other Klipsches.
These were made in fall of 1994. Judging from the 2.5" tube ports these must be early Series 2 CF-4s. Series 1s were made through the first part of 1994 and were tuned a little differently from Series 2. All of the components save the port tubes were the same. I have A/B'd both Series 1 and 2 and find them both to be equally amazing. PM me for more of my impressions on that front.
I know that this is not the typical Polk Forum fare but I thought I'd post here and see whether anyone is interested.
thanks, and PM me with any questions
Frequency Response: 34Hz-20kHz(+-)3dB
SENSITIVITY: 102dB @ 1watt/1meter
POWER HANDLING: 300 watts maximum continuous (1200 watts peak)
NOMINAL IMPEDANCE: 8 ohms
TWEETER: K-63-KN 2" (5.08cm) Aluminum diaphragm compression driver
HIGH FREQUENCY HORN: 90(o) x 60(o) Tractrix(r) Horn
WOOFER: Two K-30-KN 12" (30.48cm) Poly carbon graphite cones
ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
ENCLOSURE TYPE: Bass reflex via dual front-mounted ports
DIMENSIONS: 44" (111.76cm) x 17" (43.18cm) x 19" (48.26cm)
WEIGHT: 108 lbs. (48.99kg)
FINISHES: Whitewash, Lt. Oak, Med. Oak, Cherry, Walnut, Black Satin
Built From: 1994
BUILT UNTIL: 1996
Built From: 1994
BUILT UNTIL: 1996
HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100
Hello, your cf4 are they still available?
Best regards
Greg -
Hi ggggrrreeg,
Thanks for asking -these are no longer for sale. I had two pair and sold one. I am holding on to the other pair - they are amazing!HT System:
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100
