Grills on lsim 707 fall off
polkman1981
polkman1981 Posts: 4
edited August 2014 in Customer Service
When watching movies that have alot of bass the grills on my lsim 707's fall off. Any suggestions?
Answers
    F1nut Posts: 49,704
    Set your 707's to small and let the sub handle the bass.
    Remove the grills when watching movies.
    Use industrial Velcro to attach the grills.
  • Wouldn't setting them to small take away from what they can do?
  • Msabot1
    Msabot1 Posts: 2,098
    They look great with the grills off....love that array....
    F1nut Posts: 49,704
    It would roll of the bass below 80Hz (if that is where you set the crossover point) to the sub and may actually improve the mids/highs of the 707's. What are you powering them with?
  • I'm using a Yamaha rx-a3030bl receiver as a preamp with a b&k reference 7250 series 2 amp
    F1nut Posts: 49,704
    Ok, you should be good on power. Anyway, try setting them to small, crossed at 80Hz and see what you think.
  • Ok. I'll try it and see. I have the 706c center and have that set to large as well. I'm using an m&k mx100 sub for now
