SVS Subwoofer question
gudnoyez
Hey all losing sleep over this one the wife gave me the ok to put up only she said Only a 3.1 system upstairs since we moved the main HT rig downstairs. I looked at HSU, Velodyne, and SVS, for some apparent reason I keep going back to this one or its little sibling the SB 1000. Does anyone own this particular model or any other SVS and could give me an opinion?
http://www.svsound.com/subwoofers/sealed-box/sb-2000?gclid=CLCmz5uerMACFUNgMgodmHAAtA
I don't own one of those models but I do own a SVS. My suggestion would be to call them. Give them your room size, listening habits, equipment, etc and they'll recommend the right sub for you. Their CS is top notch and they won't try to upsell you.
Kens right, I called SVS and they were very helpful on what would work the best for my setup. Give them a call!Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Thanks guys will do but do you think they would be a better choice than HSU, or Velodyne.? Since I can't demo any of these.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Can't go wrong with any of them IMO. SVS offers a 45 day trial with free shipping both ways. Hard to go wrong with that...
And don't let the "outlet" name scare you Steve. They have the same warranty, are fully factory testing and inspected (cosmetic flaws are the only ones that end up in the outlet) and included the 45 day/free shipping both ways trial.
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
They are great to deal with.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Don't sell HSU short, they too have great customer service and products. Give them a call while you are at it.
I currently own a PB13 but have owned HSUs as well. In my former very large room the PB13 did the trick, I wanted 1 sub and I needed 2 of the HSUs in that room.
My current house the PB13 is loafing and taking it easy and the HSU would be a better fit.Speakers: SDA-1C (most all the goodies)
Most of the HSU's in that $600-$700 price range are down firing ones what's the performance difference between front firing and down firing?Home Theater
null
I always wondered the same thing.
Front vs Rear firing- I had the Polk psw10 and have the Polk psw505. The psw10 front firing seemed easier to find a placement VS the rear psw505.
I never had a downfiring one. So I am curious as well.
Cheers!Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen"
