SDA-SRS Binding Post Plate Project
stogie
I had the aluminum discs laser cut, then I drilled the appropriate mounting holes. Then they were powder coated. Finished off with Speakon interconnects and Cardas binding posts. Douglas Connection supplied the DIY parts to build the speaker cables, interconnect cable and jumpers (cable, cable sleeving, cable splitters, spades, bananas, heat shrink tubing). More importantly Doug was only a phone call away to offer assembly advice and tips. Great guy and great company. http://www.douglasconnection.com/ I hope the pictures are attached- I'm having a hard time figuring how to manage attachments.
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
TT: Technics SL-MA1
Post edited by stogie on
Nice!
Awesome!!
Looks Great!!! -
Nice job!
FYI, Trey (VR3) sells brushed aluminum binding post plates pre-drilled for the SpeakOn and binding posts.Political Correctness'.........defined
President of Club Polk -
Very, very nice work! With new binding posts and new jumpers, I'm sure the improvement is not subtle. N'joy!
As F1 says, Trey has a very similar item. I recommend an Armacell seal around the perimeter.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
very nice work... You didn't happen to make 2 sets did ya?My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Wow those are sweet!--Gary--
Armacell has a number of product lines, what did you find that works the best? -
Believe it's called Armaflex? Same stuff as the driver and pr seals.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Nice job!
FYI, Trey (VR3) sells brushed aluminum binding post plates pre-drilled for the SpeakOn and binding posts. -
http://www.homedepot.com/p/Armacell-2-in-x-30-ft-R-1-Foam-Insulation-Tape-TAP18230/100539553
Looks like 1/8" thick is only option and what everyone is using, just wanted to make sure I purchased the right thing. Thank you. -
motorstereo wrote: »Do you have a link? Seeing how nice those plates came out is making me want a pair now.
www.vr3mods.comPolitical Correctness'.........defined
The nice comments are appreciated. To address a couple of posts above (I don't know how to use the quote thingy)
Armacell/flex as linked above from Home Depot was used to seal the plates. (torqued down over several days to compress the foam)
I made 3 sets of plates- but the extra 2 are earmarked for other SDA projects. (pictures as they are finished)
Thanks againSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5 -
Nice job, Stogie! It sounds like there would be multiple interested parties (myself included) if you made a big run of these...
Very nice work.
Maybe some etching or screen print for labeling, just in case anyone else ever needs to fool with the connections, would be a nice addition.If con is the opposite of pro, is Congress the opposite of Progress?!
