Running Dual sub question
gudnoyez
Hey quick question y'all should the subs be placed on the insides of the towers or the outsides of the towed for best performance? I'am waiting for my AVR to show up so just setting up the speakers now and would like to know sub placement I do want them up front.
Post edited by gudnoyez on
I have mine on the outside. My mains would have been too far apart for my sweet spot had I opted for the subs inside, plus they sound better there than inside, at least for my room and sitting area. YMMV, of course.
Either inside of the mains or outside is fine. Keep in mind the closer you get to the corners of the room, you will get corner gain. I approach stereo sub setup like my main speakers. Listen, move, run a room sweep, L than R and then combined. You may have to move your subs closer to or further from rear wall or even at different distances to have them low frequencies at your listening position.
Some subs have a boundary control for corner placement. My nht B-12d's have -3dB, 0 or +3dB control. Mine shore up the 25-35Hz range due to the large space my mains are in. I have them on the outside and set about a foot behind the front of my main speakers. My left sub runs at -3dB. I have stacked GIK Tri Traps in left corner, one on right corner chimney wall and one in left rear of room.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Thanks Red, we will be sitting 8 foot back from the screen so my fronts will be 8 foot apart which leaves me plenty of room either on the inside of the fronts or on the outside of them as the wall is over 20 feet. I guess I will just experiment I just wondered if there is a preferred way by those that of tried it either way.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
SCompRacer,
Nice Speakers!!!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I've personally never liked the sound of a corner placement subwoofer, evar in any room I've heard. Only done it with very weak subs when it was the only way to get a boost from it, or other placement reasons.
I do like subs placed either in the center of the room or 1/4 the room width from the side walls. Not as much ultimate output but much cleaner and tighter in my limited experience.Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
i have 2 mp3k's both of them on the outside...i set them up using the polk utility individually and then let audessy balance them to the ht pre pro...And have them both in subdudes..My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
SCompRacer wrote: »Either inside of the mains or outside is fine. Keep in mind the closer you get to the corners of the room, you will get corner gain. I approach stereo sub setup like my main speakers. Listen, move, run a room sweep, L than R and then combined. You may have to move your subs closer to or further from rear wall or even at different distances to have them low frequencies at your listening position.
I ageee and follow the same procedure. I also have GIK traps. REW makes placement and adjusting easier. Based on your AVR selection, you may have to do a "Sub distance tweak" to dial it in perfectly. The results can be outstanding. Good luck._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Thanks for the kind words!I ageee and follow the same procedure. I also have GIK traps. REW makes placement and adjusting easier. Based on your AVR selection, you may have to do a "Sub distance tweak" to dial it in perfectly. The results can be outstanding. Good luck.
I'm using a two channel pre so all I have are the sub adjustments and relocation. If I couldn't of got it right via those adjustments, I would have used a Behringer to digitally EQ them. Not visible in the right speaker pic, I am open to the main level at the edge of the two tier album rack. That adds another 25' x 20' area with 14' ceiling. My first floor area is a great lesson in room modes.
Speaker response is 25Hz - 20KHz (+/- 1.5db). I've had other speakers that dig deeper, but they all needed help in the nether frequencies on that wall. Bass is not soggy or boomy, at all. Subs come in with dubstep or organ music, otherwise the speakers do the majority of the work for most of the music I listen to.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SComp, I kinda fiqured that based on your sig. That's a beautiful set-up you have. I bet they sound amazing. The SS8's are #1 on my list right now when I upgrade. I was amazed by them at Axpona . I would love to hear them in a proper room and set-up.
Gudnoyez, what AVR did you purchase?_____________________________________________________________________________________________
DAC: Bricasti M1SE
A Onkyo TX-NR838 it's shipping from a Chicago Area Magnolia once there stock arrives.Home Theater
Tornado Red wrote: »I have mine on the outside. My mains would have been too far apart for my sweet spot had I opted for the subs inside, plus they sound better there than inside, at least for my room and sitting area. YMMV, of course.
Polkie2009 wrote: »Very nice room and system Tornado Red, love that Toronto Maple Leafs throw on the davenport sir!
Ha, nice catch. In the other pic I have a small Tim Horton wearing Leaf blue on a plaque on the end table. -
Wow, those speakers are classic looking.
