Adcom GFA 555 Pre amp connection issue?
atmalloy
atmalloy Posts: 6
Hello Polk Folks...
I have had an Adcom system since new in the early 1990s [GFA 555, GFP 555 and GFT 555 along with a Niles 4 Speaker Selector,Meridian 508 CD and Monitor Audio speakers]. I have moved over 15 times since 2000 and have brought them along the way but never set the system up.
I finally bought a house in Colorado and although its new and "wired for sound" I have a small office that I am FINANALY setting aforementioned system up. I have purchased new Monster Cable speaker cable, Monster bannana clips all around, a new Monster SS4 speaker selector as well as new Monster M1000I Stereo Cables for connection between GFA 555 and GFP 555.
THE PROBLEM: Somewhere along the way the old Monster Stereo/Audio Connection cables came off with the "female RCA input cover" on the GFA 555...(see attached pics)
So does anyone know; i)...How to replace?...ii) What else to do?...iii) Do I have to do anything?
Desperate to crank this baby up ASAP.
Post edited by atmalloy on
  • atmalloy
    atmalloy Posts: 6
    edited April 2014
    Thanks...Will do. If that doesnt work Im pretty mechanical (at least with Ducati's and such). Cant I just order some "input collars" (-) and replace myself?
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited April 2014
    I had this happen with my old Adcom GFA 545. If you still have the collar, you can slip it back in place. If not, you can replace the connectors. http://www.parts-express.com/chassis-mount-rca-jack-pair--091-1120
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • atmalloy
    atmalloy Posts: 6
    edited April 2014
    Thank you Squire...
    I will order them in any case...Well looks like nothing works for now. I now wonder if its my Adcom GFP - 555? The power seems to work as my GFT - 555 is plugged into the GFP - 555 and it is powered up when I turn on the system. But one thing I notice is that the GFP - 555 "red power indicator LED doesn't go on when powered up. [I also tried the "head phone" jack and got no sound??
    Frustrated.
  • Glen B
    Glen B Posts: 269
    edited April 2014
    I would not play around with that GFA-555 powered up before replacing the damaged RCA input jack. The hum from having the center pin connected to a full open input without the grounding provided by the RCA collar, could be loud enough to damage the speaker on that channel.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited April 2014
    Think we are talking about the same thing here. While I do not have an Adcom pre I did have a problem w/ my Onkyo P-301 pre when I used Monster Cable I/Cs. I evidently pulled one of them out the wrong way and almost dislodged the femal jack. I opened it up and there was no clearcut way of that I knew of how to resolder or replace it. I gave it to a friend who somehow redid the jack for meand it held ever since. I did call MC to complain that if there was a certain way to remove their cables it wasn't on the box. After about 6/7 months I got in themail an upgraded pair for free. Since then I learned it's called the grip'o death. BTW most of the pix did not help, some were sideways others showed the front and the rear shots I did not see the direct problem.
  • atmalloy
    atmalloy Posts: 6
    edited April 2014
    Thanks fhe report and advice...Here is a closeup of the problem...Notice the 2 main inputs (verticle center)...The top
    has a female gold RCA cover and the bottom
    does not.
    pitdogg2 Posts: 25,754
    edited April 2014
    slide it back on open top and bend tabs 90* if it has tabs. Monster grip of death now you know all about it. Bending the tabs over after insertion will keep it from happening again. You could also replace if this don't help.
  • atmalloy
    atmalloy Posts: 6
    edited April 2014
    As you suggested...I have now received the pair of "chassis mount rca jacks" from Parts Express and will start replacing the old inputs on my Adcom GFA 555...My druthers would be to have some directions (video or written). Any thoughts or ideas here?
    F1nut Posts: 50,835
    edited April 2014
    You'll just have to open it up to see what it is you'll need to remove to get at the board with the RCA jacks. However, you might want to put that on hold......
    Check the fuse(s). If they are good, your amp needs professional service, so you might as well have the tech replace the RCA jacks.
    Never plug an amp into a pre amp. Those outlets are not designed to handle the load from an amp.
    Free advice, take it or leave it. Get rid of that crappy Monster cable stuff. The speaker cables will turn green, you've already found out how bad the RCA connections are and worst of all, it doesn't sound good.
    Why are you using a speaker selector?
  • atmalloy
    atmalloy Posts: 6
    edited April 2014
    F1nut: You'll just have to open it up to see what it is you'll need to remove to get at the board with the RCA jacks.
    ATM: Opened all up and RCA input jacks are actually all in one unit soldered to the board...I also checked all other connections in Amp and they are ok as well.
    F1nut: Check the fuse(s).
    ATM: They are all good.
    F1nut: Why are you using a speaker selector?
    ATM: I am only setting it up the way it was originally set up...Although your point is well taken. I guess with only 1 set of "Monitor Audio" speakers I don't need a speaker selector?
    F1nut: Never plug an amp into a pre amp. Those outlets are not designed to handle the load from an amp.
    ATM: The GFA 555 is plugged directly into a "Power Wedge 116"
    ATM: Im now wondering whether the GFP 555 is not working correctly (although the power works).
    F1nut Posts: 50,835
    edited April 2014
    Sorry, I'm not up on those model ID's. Obviously, I thought you had the amp powered off the pre amp. I realize now that it is your tuner.
  • DracoAmericanus
    DracoAmericanus Posts: 112
    edited May 2014
    the RCA terminal block will probably need professional service. Sadly we are on opposite sides of the country otherwise i would offer to service it. It will need to be desoldered and replaced, if you still have the ground sleeve that tore off with the connector, it can some times be reattached and soldered back to ground
    I use older adcom my self, a GTP-500 is sitting right next to me for a 2 channel system.
    I second the other poster and get rid of the Monster cable. I have lost count on the times i have seen that "stuff" damage equipment
    There is no cure....
    Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
    8mm, 7.62x39mm
  • Phatattack
    Phatattack Posts: 30
    edited May 2014
    HeAd to monoprice, cheap and excellent quality for the win!
    tonyb Posts: 33,027
    edited May 2014
    Phatattack wrote: »
    LOL.....cheap, yeah.....excellent quality ? UH...NO. Excellent sound ? Another no. May as well go to Walmart, same stuff.
