RTiA7 and CSiA6 Crossover Upgrades - A Slightly Different Approach
F1nutF1nut Posts: 39,989
edited January 2015 in DIY, Mods & Tweaks
I decided to finally upgrade the crossovers in my HT speakers. I purchased 3 of Trey's (VR3) beautiful aluminum binding post plate kits, but after I got them decided I wanted to do something slightly different. Instead of stacking I wanted a more modular design and decided to mount two panels horizontally on the rods, the top panel would have the tweeter/mid circuits on it and the bottom panel would have the woofer circuits. I wanted to be able to slide each panel onto the rods, so I purchased custom cut unclad FR4 black boards (PCB) to which I attached square hollow aluminum tubing with 3M VHB tape. I needed a slightly longer length than the rods that came with the kit and I wanted to use stainless steel, so new rods were purchased. At the rear end I used one of the Delrin plates that came with the kit. I mounted a Molex type connector block to it and the mating connector to the internal wires. This makes it a breeze to remove the crossovers if needed. Of course, I stuffed the boards with Sonicaps and Mills. All point to point wiring with panels installed to cover the wiring. I used stainless steel socket head bolts and Hurricane nuts to attach the new crossover plates to the cabinet for a complete custom look.
The new RTiA7 crossovers
The original RTiA7 crossovers minus the inductors
Rear view
The new RTiA6 crossover
View of the other side
They are still burining in, but right away I noticed that the soundstage width increased dramatically, the slightly edgy treble is now much smoother and there is more weight to the mids.
Post edited by KennethSwauger on
«13
  • B RunB Run Posts: 1,896
    edited April 2014
    Wow you did an awesome job, those look great!
    Living Room: Polk Lsim705’s, Lsim 704c, SVS SB12-NSD, Yamaha Rxa-2030, Denon DBT1713, Doug's Furutech SC's, Pepster PC's, Vizio 75" 4K M Series, Airport Express
    Bedroom: 70" Vizio, Pioneer Vsx530, Boston Acoustics CR7’s
    Theater Room: BenQ HT2050a, Stewart Firehawk 110", Pioneer Elite SC63, Lsim703’s, LSiM706c, Lsim 702f/x, SVS SB12-NSD, Xbox One
  • F1nutF1nut Posts: 39,989
    edited April 2014
    Forgot one, with the cover panels installed
    edited April 2014
    I don't know anything about rebuilding crossovers nor mean any offense to Trey's design but that seems like a simpler and cleaner design as long as the caps aren't much larger.
    edited April 2014
    It was actually very labor intensive. I had to cut the SS all thread to length, rethread the cut ends and smooth out the burrs. The tubing walls are extremely thin, so I had to rough cut them with a Dremel cut off wheel, then hand file to length. The lay out took a while to get it just right, then figuring out where to drill the holes took a while as well. I was able to use the first A7 board as a template for the second, so that went faster. I used pin/socket connectors for the wires, but had to cut them shorter, a real PITA. Then soldering them to the pins of the Molex without melting the Delrin was yet another challenge. There's a lot more, but I'm sure you get the idea.
    Thanks for the compliment.
  • headrottheadrott Posts: 5,293
    edited April 2014
    Very nice job Jesse! Seems like a "less crowded" design. Congratulations and enjoy the improved sound.
  • westmassguywestmassguy Posts: 6,068
    edited April 2014
    Very nice Jesse! Enjoy them.
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
  • gudnoyezgudnoyez Posts: 6,254
    edited April 2014
    Nice job looks like all your hard work paid off. How many hours did you have to put into the project?
  • KennethSwaugerKennethSwauger Moderator Posts: 6,531
    edited April 2014
    Beautiful work!
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • drumminmandrumminman Posts: 3,354
    edited April 2014
    Nice work Jesse!
    Fyi, I've cut aluminum similar to the square hollow spacers with my compound miter saw using a carbide tip blade - fast and neat.
  • monepolkmonepolk Posts: 839
    edited April 2014
    Nice work!
  • EndersShadowEndersShadow Posts: 15,750
    edited April 2014
    Too bad they are stuffed inside the speaker.
    I would almost want them fully external with a see-through plexi cover to show off my work.
    Its kinda like a hot rodded car..... you gotta be able to just pop the hood to show off the goodies easy :smile:.
    If I ever get my LSi's modded, I would love for the new crossovers to look like that. Work of beauty Jesse!
  • pitdogg2pitdogg2 Posts: 10,232
    edited April 2014
    I've tried to come up with some off the wall remark, but instead I find myself in agreement with all here
    awesome job
  • TNHNDYMANTNHNDYMAN Posts: 2,153
    edited April 2014
    Beautiful work Jesse. Looking forward to your listening impressions of the improvement after they break in for awhile.
  • FaceFace Posts: 14,714
    edited April 2014
    Great job Jesse!
  • polk500polk500 Posts: 1,180
    edited April 2014
    Awesome skills enjoy the improved sound.
    Cheers
    Roger
  • OldfatdogsOldfatdogs Posts: 1,885
    edited April 2014
    Very clean job Jesse,but I thought you were woodworker.:razz:
  • ConradiclesConradicles Posts: 5,735
    edited April 2014
    Good job!!!
  • ZentishZentish Posts: 127
    edited April 2014
    Drop Dead Sexy!
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
  • eclypseeclypse Posts: 589
    edited April 2014
    Very awesome job man!! Yeah i agree, i would want to still see them inside the speaker.
    How about photo of them framed on the wall behind and above the speakers? Haha.. that would do it! ;)
    Would love to one day do mods formu lsim when i get bored.. maybe 5-10 years from now.. new 14 year old house has be busy! haha.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • Inspector 24Inspector 24 Posts: 1,063
    edited April 2014
    Definitely deserve an external mount.
    This is awesome to hear. Some time I want to upgrade my A9's, I'd love to smooth out the treble even more than the Parasound did.
    Down
    RTiA9 - CSiA6 - FXiA6 - Dual HSU VTF-15H Mk2
    Sim2 D60 - Dragonfly 106" Panny 500
    Up
    LSi15 LSiC - RX-V3000
    edited April 2014
    Im sure everyone would like to know how much and how long did this job take?? Ok atleast how much more then the parts from the mod master himself?
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    edited April 2014
    Thanks guys, much appreciated.
    Cost, you can price the caps and resistors at Sonic Craft. The binding post plates you can price at VR3mods. I would guess all the rest was about $150.00. Time, about 2 days (16 hours) for everything.
  • BKphotoBKphoto Posts: 406
    edited April 2014
    wow, clean, impressive...
    B&K ST2140 - NAD 1020 - Project Debut Carbon-
    Speed Box S - CA Azure 551P-
    Infinity RS IIIa - Blue Jeans IC's
  • gcegce Posts: 2,146
    edited April 2014
    Wow very nice! Maybe I should of had you do mine instead of Tray...j/k :razz: Tray did a great job and the sound is so much better.
    Anaheim Hills CA,
  • VR3VR3 Posts: 22,070
    edited April 2014
    Looks great Jesse!
    Excellent take on the stack design that I had never really thought about. :)
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    edited April 2014
    VR3 wrote: »
    Looks great Jesse!
    Do I sense a new "version" of the mods coming :smile:
    edited April 2014
    Jesse had called me a few days ago when he completed these and as I was telling him -
    I can do my Fortress design in about 3-4 hours now from start to finish. This design being based around the tubing to have the substrate attached to slows it down tremendously due to how you have to cut it.
    I have changed a lot of what I do and take in modification wise.
    I love to see stuff like this though! :)
  • halo71halo71 Posts: 4,382
    edited April 2014
    Wow! Those look very very nice.
    --Gary--
  • zane77zane77 Posts: 1,711
    edited April 2014
    Very nice and clean job Jesse
    Two Channel
  • mdaudioguymdaudioguy Posts: 4,491
    edited April 2014
    Pretty cool, Jesse!
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
«13
Howdy, Stranger!
