Atrium 5 / Atrium Sub10 Amp Recommendations?
Getting ready for summer here even though the highs are still in the 40's.
I've never used a subwoofer and never set u an outdoor system, but I bought the Atriums at the friends and family sale and now I need to power them.
I'd appreciate any suggestions for an inexpensive amp and guidance on the set up.
Thanks very much.
Thanks very much.
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Post edited by stretchl on
cheap receiver off craigslist....HT SYSTEM-
lsi 9's -
With the subwoofer and 2 speakers can it be a 2 channel receiver, or do I need a HT receiver, ie. 3.1, 5.1, whatever.1?
Thanks very much.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
Depends upon how the subwoofer hooks up. I would assume you could use speaker level connection and use either a 2-channel or HT AVR.Things work out best for those who make the best of the way things work out.-John Wooden
OK, cool. I'll break out the sub and... gulp... read the instructions!... this weekend.
Any advice on speaker wire for outdoors?
Thanks!“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Thanks very much.
I believe with that sub, you'd need a subwoofer output. Some 2 channel receivers have them, some don't. In any event, a 5.1 receiver will and any of the older robust models can still be had on the cheap.HT SYSTEM-
lsi 9's -
Thanks!
What sub did you buy? Some you can connect the RCA's straight to it for Left/Right and then use the crossover in the sub to send the some to the sub some to the speakers. Some you cant and then you would need to use a HT AVR w/ sub out.
Speaker wire for outdoor I would probably use some in-wall rated cable so anything CL rated. You might even be able to use cable normally used to power exterior lights for your use, but it may be hard to tell the polarity at each end if you dont mark it."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
It's the Atrium Sub10.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Ok so just read the info on the Atrium sub10 and it looks like it is unpowered built has a built in 150 hz low pass filter (i.e. crossover). So that may make it a bit more complicated...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Looks like I need to get my read on before summer comes. Of course, since I live in central Illinois, that gives me about four months or so.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
