Boozehound JFET Phono/RIAA Preamplifier & JFET Moving Coil Pre-Preamp
pumpkinman
I've never built anything before (ClassD amp yes but no soldering was required)
So I'm game. I will have tech support from a member of a AudioCircle so I'm not to
worried. He has a power supply that's already built and will donate to my project.
To build a case I'll need to go up the garage so that'll be awhile.
It's still much to
Because I am The Pumpkinking
Post edited by pumpkinman on
Ok I'm not quite sure what I'm looking at it is a phono stage and a step up for a MC cart?
Did you buy them like that or did you have to put all the caps and resistors on the boards?
No soldering, do they just go in the holes and then crimp on bottom?
Cost??ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Cost??
http://boozhoundlabs.com/collections/kits/products/bhl-audio-jfet-phono-preamplifier-kit-2sk170-riaa
http://boozhoundlabs.com/collections/kits/products/bhl-audio-jfet-moving-coil-pre-preamp-phono-kit-2sk170
No the boards do not come assembled so soldering is required. I bought both the phono pre / RIAA and the step up for MC
Cost was $138
Total cost when completed ???? Don't really know.
